sheet metal modeling
I am trying to model a sheet metal part in solidworks 2003 by lofting 2 sketches. My problem is that I cannot keep the thickness constant throughout to be able to add a sheet metal feature later. I'll describe a simplified version of the problem area of the part. If looking at the part from the side when flattened, it would look like a flat sheet with a bend from one side to the other on a diagonal. When you create this affect using a loft with 2 sketches the thickness of the bent section is changed. This makes sense, but I do not know of a better way of doing it without laying it out on a flat sheet. I would appreciate any help that could be given.
Jeremy Estes
Jeremy Estes
RE: sheet metal modeling
Sheet metal must stay the same thickness to be considered Sheet metal in SW. You may look at trying to use Conical shapes in SW Sheet metal.
Best Regards,
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.3dmca.com
FAQ731-376
When in doubt, always check the help
Scott Baugh, CSWP
FAQ731-376
Crashj 'would like to be thin, too' Johnson
Jeremy Estes
