Global Text Style in Acad2000
In R14 , I could use CHT to change text style in any part or entire drawing, in Acad2K , does not work! What is new command to change text type in entire dtawing or selected ones?
thanks
RE: Global Text Style in Acad2000
Select the text then right click and pick properties.
Then change the text style and other properties as you wish.
Steve Smith
Product Engineer
Staco Energy Products Co.
www.stacoenergy.com
type "mo" the object properties table appears.  Select all the texts you want to change and change the appropriate properties.
Shajitha
