Helium leaks: ppm & mbar*l/s
   In order to perform valves Fugitive Emissions tests, we use a VARIAN sniffer probe helium leak detector, which gives readings in mbar*l/s. Our usual European reference specification (Shell MESC SPE 77/312) also gives limits in the same measurement unit.
   First of all, is anybody able to explain the physical meaning of "mbar*l/s"? Is that a flow rate or a concentration?
   Then, how is it possible to relate this with "ppm"? As many leak detectors manufacturers have instruments with both scales, we think there must be a simple relation between the two units.
        Many thanks in advance, 'NGL
