allowable stress in tension for Vton A
I would like to know the allowable stress in tension for Viton A rubber expressed either as Pounds per square inch or elongation %.
Saitools
Saitools
RE: allowable stress in tension for Vton A
All temperatures are ambient.
Rajan
Allowable stress is the yield stress divided by factor of safety (for materials with elongation greater than 5%), with factors of safety range between 1.5 and 4.0.
When I worked on NASA contracts the factor of safety was dictated prior to any design (normally 1.5). I was told by an aircraft engineer their factor of safety for design was 1.25.
If you have test capabilities you may want to run some samples.
Please advice
Thanks a million
Best regards
Rajan
You have been most helpful!
Million thanks.
Best regards,
Rajan
