What codes specify frost depth
In most cases selection of depth of foundation based on intuition or experience is fine, however when every inch of excavation matters economically, I have to explain to someone that I can not put the base of foundation above some level.
What codes specify the minimum depth considering frost.
Thank you in advance
RE: What codes specify frost depth
It is from US Corps - Pavement division
Download at http://pavement.wes.army.mil/downloads/draft/modberg.exe
It is based on modified Bergreen equation.
Hope that this helps
http://www.pangea.ca/~halim
you may also find useful information at the US Army Corps of Engineers Cold Regions Research and Engineering Lab. Many technical papers may be downlaoded there.
http://www.crrel.usace.army.mil/
