installation of thrust bearing
hi all !!!
we r working with a thrustbearing of size 10 (2" inner diameter) and it has to be mounted inside an acrylic sheet.
the bearing will have to work loads upto 5 kg.
i wanted to know how can we mount the bearing inside the acrylic sheet because it is not possible to heat fit the acrylic sheet.
Also once the thrust bearing is fitted inside the acrylic sheet how do we mount the shaft on to the bearing?
