CAN TYPE PUMP
CAN TYPE PUMP
CAN TYPE PUMP
I have some questions here.
1. I need an ammonia pump (vertical can type) with specification : capacity 30 m3/h, total head 13.5 kg/cm2,
and NPSH A. = 0.4 m. Is it possible to get a pump  with dia. Of barrel < 700 mm and distance between
center line of suction nozzle and bottom of barrel < 1700 mm ?
2. Which material is the best for pump to handle Ammoniated phosacid, HA 28.5 : 654 SMO : HV 9
HA 28.5: 26-28 % Cr  : 5-7 % Ni  : 3-4 % Mo : 0.03-0.46  % C
654 SMO: 24 % Cr       :  22 % Ni  : 7.3 % Mo : 0.01 % C
HV 9   : 19-22 % Cr  : 24-26 % Ni  : >4 % Mo  : 0.04 % C
RE: CAN TYPE PUMP
You'd be better off contating pump companies directly.  There 'might' be someone here who works for one AND who makes what you are looking for but IMO that's a long shot.
