CAN TYPE PUMP
CAN TYPE PUMP
CAN TYPE PUMP
I need an ammonia pump (vertical can type) with specification : capacity 30 m3/h, total head 13.5 kg/cm2and NPSH A. = 0.4 m. Is it possible to get a pump  with dia. Of barrel < 700 mm and distance between center line of suction nozzle and bottom of barrel < 1700 mm ?
RE: CAN TYPE PUMP
the best solution is to forward all process conditions, fluid properties, and any space limitations to vendors and have the vendors determine whether or not your requirements can be met.  actually, you the engineer should determine whether or not the proposed pump will meet space requirements.
the case may be that you will need to make design changes.
-pmover
