Tables in AutoCAD2002
To anyone who might know, but specifically to "CADQUEEN"...
By downloading "Express Tools" and using using the "sync attributed block to table", it would add up those values and show the result on a table within the drawing file (i.e. not in an Excel or other software file). If I change a value, would / could it recalculate and update the result? Is this table automatically generated or do I need to create it (and if so, how)?
RE: Tables in AutoCAD2002
DO YOU HAVE BUILDING SERVICES..ie mechanical/electrical?
If you do this is a breeze...if you don't I HAVE created a VBA ROUTINE THAT WILL GET THE JOB DONE!
Let me know, I don't mind sharing:)
have a good week-end!
Cassy
I would very much like the VBA routine you mentioned.
You can e-mail it to me at bill.phillips@usa.com.
Thanks for all the help!
