Turning titanium on a CNC lathe
I'm trying to find out what the best tooling is to machine titanium (grade 2) on a CNC lathe and CNC mill. I'm currently using uncoated carbide inserts and tools. Is there anything that I can use to increase speeds and feeds without warping the part? Thanks....
RE: Turning titanium on a CNC lathe
Increasing speed is not usually recommended when machining titanium.  Increasing feeds can be used when using the latest generation of tool inserts, copius amounts of coolant, and proper machine set-up (fixtures, geometry, etc.).  Ceramic inserts with very sharp edges are replacing micrograin carbides and coated carbide inserts for roughing and finishing of titanium alloys.  You can find a lot of information on machining of titanium from the following websites:
Machining sites
http://www.mmsonline.com/articles/070204.html
http://www.ctemag.com/pdf/0212-confgame.pdf
http://www.ctemag.com/article/viewArticle.asp?ARTICLE_ID=156
http://www.ctemag.com/article/viewArticle.asp?ARTICLE_ID=94
Titanium producer & distributor sites
http://www.timet.com/design&fabframe.html
http://www.deutschetitan.de/eng/profi/kb3.html
http://www.titanium.com/tech_manual/tech2.cfm
http://www.leichtmetalltechnik.at/html/machining_titanium_and_titaniu.html
Use PVD coated micro grain inserts,with sharp edges,try to avoid 95 degree lead angles.
I'm an expert on super alloy machining.
Look into turning (finishing) with PCD diamand tipped inserts,if you feel like it talk to Seco Tools.
