Resizing Datum Planes
We r using UG V 16.0.4
How can we resize datum planes to fit the model, once the model is ' finished ', so that they are only as big as they need to be ??
RE: Resizing Datum Planes
Feature related planes should update when the feature changes size.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Chad Richardson
DARcorporation
I had the same problem,
we are using a simple shortcut to achieve it.
1.Put a very big block(using block option)to the size of the model you have.
2.Now use the resize fixed datum planes,Now your fixed datum planes sizes will change.
(i have tried in UG 18 it is working fine)
3.Delete the block you have created.
I believe there is no other method to achieve it.
Karthikeyan.J
