Problem With Sketches
When i am in the drawing mode, i sometimes want to put a sketch on a view (just adding some minor detail). I constrain the sketch fully.
I then go back to the part model and change a dimension. But when i update the drawing the sketch becomes unnatched, but i fully constrained it, so why is it happening?
On several occasions a sketch line which had a vertical constraint on it was at about 45 degrees, why?
