SERVO VALVE: Maintenance & Flushing Proc.??
I am trying to implement a simple, regular maintenance schedule and proper storage guidline for our current hydraulic servo-valve stock.
PROBLEM1: 2 diff. petro-based oils used (therefore, all Buna seals...) but what is best & simplest way to clean & purge a valve used with 1 oil when switching valve to another oil type or just putting valve into storage? **considering using N2???
PROBLEM2: We also use Skydrol oil (therefore, EPR seals)in other servos, and have endless trouble with leakage? Anyone using servos with EPR seals with success or lessons learned?
ALSO: Considering a once/yr interval checking & cleaning main servo filter & changing seals.
Thanks in advance.
Jason Coulas
Test Engineer
