Diesel fuel piping?
Diesel fuel piping?
I am installing a day-tank for a diesel generator. What type of piping should be used between the day-tank and the main diesel tank?
Thanks in advance.
Thanks in advance.
RE: Diesel fuel piping?
Do not use any galvanized pipe. Zinc will leach into the fuel and cause injector problems.
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
What is "black iron pipe?" and what protection does it need if it is going to be buried in the ground? Can "black iron pipe" be purchased with an anti-corrosion coating?
Check the code requirements for fuels in your area. If you're going to bury a fuel line, I'd bet you have to meet the same standard as the gas station operators.
2) Typically it is socket welded sch 80 for 2 inch and smaller. Hook ups to the generator should be an approved flexible hose, as opposed to hard piped.
3) Buried fuel piping is typically installed in double containment piping. The project I did used 1 inch carbon steel piping contained inside a 3 inch fiberglass containment piping system.
