Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I really enjoy your site. You have a lot of helpful and friendly experts who contribute so willingly. Thank you for past (and future) technical advice..."
Geography
m240 (Military)
6 Mar 03 12:08
By making the angle of a chamfer basic does this mean the angle has to be "Perfect"?
There is a discussion here about the validity of showing the angle as a basic and using the tolerance block in the drawing title block to control the chamfer size. Thus allowing angle variation within the limits of the depth of chamfer.
Is this a valid way of controlling the angle of the chamfer?
One discussion is to have the angle tolerance dictated by an angular tolerance in the title block.
Our ANSI Y14.5-1994 book does not discuss this.
Any help would be appreciated.
Tony
m240 (Military)
10 Mar 03 9:42
ANYONE?
GDTGUY (Aerospace)
10 Mar 03 13:46
The purpose of making a dimension "basic" is to exclude it from the title or drawing block tolerance.  So, assuming the block tolerance applies to a chamfer defined by basic dimensions is incorrect.
If you use basic dimensions, then you would need to also apply an appropriate geometric tolerance (probably a profile tolerance) to define the allowances for the surface.
ASME Y14.5M-1994 defines several methods for specifying a chamfer in paragraph 1.8.15 (page 14) and Figures 1-41, 1-42, 1-43 and 1-44. (pages 17-18).  All of the examples illustrated would default to the block tolerance as long as they were not enclosed in a box.  Select the method most appropriate for your application.
Hope this helps
GDT GUY
m240 (Military)
10 Mar 03 14:14
Thank you! This is what my associate and I were thinking but without our '1994 book (lost but another one on its way) we could not prove or dis-prove.
Thank you again!
Tony
Close Box
Join Eng-Tips® Today!
Join Us             Close
