hand vane tester
hand vane tester
I am looking for a small field hand vane tester for measuring shear strength of soft to firm marine soils. I saw a tester a couple of years ago with the same size vane as the laboratory vane (13 by 13 mm). There are hand vane testers with larger vanes (19 by 28 mm) but I need a smaller vane to sample split cores.
RE: hand vane tester
