flash point definition
Hi....
did you ever heard of a "chevron flash point"?
If yes, could you kindly give its definitions?
RE: flash point definition
Could it be the flash point of a Chevron (company) 15W-50 (multigrade) brand of lube ?
Thanks for your answer but my question is more general.
I red that definition on a gasoil specification where it is normally used something like
- cleveland open cup
- abel pensky
- pensky martens
- tag
Could someone give other help?
Google doesn't find anything other than flash points on Chevron products as 25362 suggests.
Chevron has a home page, have you tried contacting them?
open cup methods apply to open tanks, like a can of beans with the top taken off or an open top oil drum with the top taken off. Closed cup methods approximate the conditions in a closed tank with an atomospheric vent.
Cleveland Open Cup is an open cut method - dah!
Abel Pensky is a closed cup method - Google
Pensky Martens ? http://www.petrolab.com/pfla.htm will mail you pictures of these, maybe open and closed cup
Tag, I think make open and closed cup devices.
HAZOP at www.curryhydrocarbons.ca
