Edge distance for a tapped hole
I need to put tapped holes in the face of a piece of metal plate (316 SS).
Can anyone tell me a good reference - or better yet just tell me the answer - on calculating how close a tapped hole can be to the edge of the metal plate.
My current thought on being sure that I am capable of developing the strength of the bolt is that the tapped hole depth and edge distance would be at least that of the nuts that come with the bolt.
Alan
Alan
RE: Edge distance for a tapped hole
in the bearing industry assuming you are measuring
from the center of the bolts.
The AISC spec and IFR's aluminum recommendation both cover cases when bolt is in shear and towards the edge of the plate.
DiamondJim's standard more closely matches my toughts on a nut; DJ=> 1/2" for a 1/2" bolt; for a 1/2" heavy hex nut =>7/16".
Diamond Jim, are your bolts likewise in tension only?
More thoughts from all are appreciated.
Alan
Almost all of our applications are in tension only.
We make large ball and roller bearings where the
bolts fasten our bearings to customer structures
and to the cranes above the bearings. We recommend
pilots to take any shear loads. VDI2230 has some
good information about end distance for different
thicknesses of material verses bolt clamping length.
The compressive forces make a conical wedge force
much like a stone hitting a window. The hole is
small on the initial contact side and much larger
on the opposite side.
Since you state that the hole will react only the joint preload, then your comparison to nut wall thickness is understandable. View this thread for calculating wall thickness:
Thread404-44696
