How do I remove acetone from waste water
I have nine 400 gallon totes of wastewater containing acetone (about 200 ppm) that I need to treat to remove the acetone so it can be discharged to the local POTW. Is there a simple effective way to do this?
Thanks.
RE: How do I remove acetone from waste water
You could try activated carbon filters.  Stong UV and Ozone might also be used to oxidize and break the carbon structure into CO2.
what about aeration?
contéact arbochim@online.be they will give you the solution
