ACAD 2002 Dimension settings
Remember in r-14 you had direct access (thru the dim dialog)to various kinds of dimensioning (linear, angular, radial...) and could change variables for a particular dimensioning type without affecting the others? I'm confident there's still a way to do this in 2002, but its just not obvious to me. I COULD go back and research the individual dimensioning variables, but that seems to defeat the purpose of the new and improved dialog box approach.
Also- anyone seen the dimensioning dialog in 2004 yet? has it been "improved"?
Thanks-
C. Fee
Thanks-
C. Fee
RE: ACAD 2002 Dimension settings
I'm pretty sure there isn't a button you can click on to overide dim variables like in r14 though.
Flores
I'm really disappointed that this and some other changes happen as "improvements" leaving us with only work-arounds as alternatives. Yes you can change a particular dimension thru properties, but I'd rather not have to go through that extra set of steps, except in those instances where its appropriate to do a series of dimensions, and only modify one aspect of a couple that need to vary. I'll be even more curious to see what other "improvements" are in store with r-2004. Any feedback yet from early adopters?
Thanks-
C. Fee
