Unbalanced Chilled Water Piping
we have a main chilled water pipe branched to tow circuits , one of these circuits has been canceled and by passed. when we try to close that bypass and keeping the all water go in the other circuit the cooling capacity of that circuit is decreasing. Is that physicaly accepted!!?
any response will be appreciated.
RE: Unbalanced Chilled Water Piping
That doesn't sound right to me, there's got to be something else going on in your system if that is what you are seeing.
You had a total water flow = flow to circuit one + flow to circuit two. Now you are taking flow to circuit two out of the system. Not knowing how your piping network is designed. You may have less flow to circuit one now than you did before.
