thread lock problem
thread lock problem
thread lock problem
                                                   Hi everybody I'm new here, and have a question that I sure would appreciate some input on. I need to find a cold or low heat way to permanently bond an adjustable machine handle with inside threads, to a threaded tool shaft. I need to twist the handle clockwise and counter clockwise with quite a bit of pressure, so the threaded parts need to be locked together tight, and permanent. I know high strength red Lock Tight isn't strong enough for this. Maybe a thin bodied 2 part epoxy? Does anyone have any ideas here? Thanks for any help.
RE: thread lock problem
Would it be possible to fit the handle, cross drill the joint then fit a spirol or spring pin?
I wish I could. The problem is the female threaded portion of the handle is covered by the handle housing. The only way is to lock the threads together chemically. I thought of a low temp solder, but it might weaken a spring that is also in the housing. A thin, two part epoxy seems to be the best solution, but I don't know which to use, or if there is a better solution. Thanks Atad.
Sounds like it's time to make a call to Loctite. You may be correct that an anaerobic type product won't work but they will be able to recommend something that will.
If an anaerobic plastic (Loctite) doesn’t work you may have to change the thread size. There is a company that makes a tap with a self locking thread.
Another method is to extend the thread through and lock the back side with a nut.
If the handle does not have any bearing, put bearings in it to reduce the torque on the threads.
If you make a handle or buy one from someone there should be a shoulder larger than the threads to work best.
Carr Lane and Fairlane sell handles, as well as others, I can’t remember the name of the company that makes the tap for thread locking.
You could drill and tap the end at the interface between internal and external threads and install a setscrew. Use the loctite there if you want.
