On/Off control for 5V regulator
Hi all,
I am powering a device using the LM7805 (5V regulator). I want to be able to turn the LM7805 on and off. The LM7805, as you know, doesn't have the on/off pin. Is there a way to do this? What's about using the LM317?
Is there any 5V, 800mA regulator out there that has the on/off control? Thank you in advance!
Thomas
Thomas
RE: On/Off control for 5V regulator
G :)
Thank for helping me! I want to control the on/off pin directly by a microcontroller running on 5V. The maximum source/sink current of the microcontroller is 20mA.
Thomas
http://www.national.com/parametric/0,1850,663-c8-1,00.html
Many of these are available from Digikey etc.
