Dual-band microstrip antenna for 900MHZ and 2GHz (help!!!)
Hi all,
I recently designed a Plane inverted F antena (PIFA) for Dual-band microstrip antenna for 900MHZ and 2GHz, however, when i do the adjustment, it is difficult that both frequencies dB are very low, nearly 8-9dB.........so is that any other way to solve this???
Ragerds,
Raymond
Ragerds,
Raymond
RE: Dual-band microstrip antenna for 900MHZ and 2GHz (help!!!)
http://www.ece.queensu.ca/hpages/faculty/freundorfer/V5/wireless/antennae/aper_coup_ant_1.html
http://www.cwc.nus.edu.sg/~chenzn/MOTL-0802.pdf
http://cetaweb.mit.edu/pier/pier23/9808252.Gao.Li.pdf
etc. for more info
Possible causes:
1. High attenuation due to an inadequate physical design
2. Some flaws in the material
3. Etc.
