prefabricated foundation
I'm looking for any information about prefabricated foundation, including footing. Any info. will be appreciated.
In fact, I'm not sure if there are any foundations that are
prefabricated off-site, transported, and installed on-site. Anyway, please probvide me with any info.
RE: prefabricated foundation
What's your application? Location?
We then in one evening we excavted the hole, (sheeting was not reqiured as there was no railroad loads and the hole was otherwise suficcently stable, threw a little stone in the bottom to make a level grade, set the unit and backfilled. It worked well and we have used the method since that time. The only problem is that the precast foundations become heavy quickly and size will probly be limited by the equipment that can set it.
