Excel Macro - Ctrl-Home
Hello All,
What is the excel vbe code to move the cell pointer to the top left (home) of a frozen pane?  I need the same effect as ctrl-home would have without the cell reference as the location of the frozen pane will change constantly.  Hope this is clear.  Thanks a lot for your help
RE: Excel Macro - Ctrl-Home
Yevette,
Sorry its not clear, but if I understand you correctly, a simple use of "??=??" will do.
One VBa equivalent of CtrlHome in Excel would be Range("A1").Select. I don't know if this is what you are looking for, though.
The VBA / VB / Visual Basic equivalent of the
ctrl-home keyboard shortcut in Excel
that works for split / frozen window panes is:
cells(activewindow.splitrow + 1, activewindow.splitcolumn + 1).select
You might want to check the split and freeze state of the window, too.
