Comparaison with AutoPIPE
8
Should we use Autopipe or Ceasar II. Which one is the most user friendly?
RE: Comparaison with AutoPIPE
I have the AUTOPIPE PLUS it is comparable to CEASARll, and has a very good backup regarding the theory and tutorials.Par example the flanges ANSI check is much simpler than in CEASARll.The price is lower as well.
I would recomend you to evaluate the main softwares available, looking for the main issues you want on each of them. Most of the piping stress software are very easy to use, depending on the way you work or prefer to organize the job run. If you usually run big and complex systems some extra edition features like copy, mirror or rotate block operations would be very useful.
Several years ago we have performed this kind of evaluation ranking the main features we want on a piping software: nozzle loads check modules, flange check module, structure modeling, substructuring, CAD interface facilities, WRC-107/297 calculation and others, dynamic analysis features, capacity to run complex jobs with several non-linear restraints, technical support, input facilities and several others. You have to judge what things are more important considering the cost benefit (do not forget the annual update).
Nowadays we have been using CAESAR II and TRIFLEX.
chappy7 (Mechanical)
I agree with Medeiros (Mechanical), I also use FE-PIPE which is the Engineering Tool's to check your stress run.
Note: you should check on the court case RE Auto-Pipe 1989!!!
Leonard@thill.biz
www.thill.biz
Isthill,
¿What do you mean  with " court case RE Autopipe 1989" ?
The Autopipe was only ever popular with Autoplant users and then not very. Caesar II is very good and much more user friendly. Might also be worth looking at PSA5 and finding out which suits you best. E-mail alistair.richardson@cea-int.com and they will supply either programme for evaluation. They also sell the FE/pipe.
What about ADLPipe? What happened to that product? I heard that there is going to be a new version of it out this year.
lsthill
Yeah, what exactly do you mean with " court case RE Autopipe 1989" ?
Is this something we should know ?
Why don't you provide  a website or newspaper reference or just SOMETHING !!!!
MJC
Chappy7,
Let us know what you went for in the end and why so others may benefit.
Isthill,
I too would like more info on the 1989 court case
PW
The facility to model steel is nearly as important as the pipe stress for any serious work, esp seismic, on large pipe (of comparable section modulus to the supporting steel).  The alternative is to assume all structure is rigid and dream.
Assuming that every support is rigid can and does produce some very conservative AND unconservative results especially for larger pipe sizes.  You don't need to model every bit of steel but you need to model those that have stiffnesses less than say 8-10 times that of the pipe or which affect the load distribution especially between supports and equipment nozzles.
The only thing to do is to create a matrix comparison, between the programs you are considering. One pt is usage... CAESAR II is very widely used.
Another important consideration is support.
Both of these COADE does a good job with....
XHPIPE
lstill,
        Come on please expand on this "court case re Autopipe" we all want to know.
Lsthill, according the information in your link, this was NOT a court case as you originally claimed and your characterization as such appears to be nothing but a dishonest smear.
Because Autopipe, unlike some of the other piping stress programs, is approved for use in nuclear safety apps, they and the govt publish an updated list of known bugs which is a standard nuclear QA requirement. I have seen no evidence of a lawsuit or court case relating to that 1989 bug you linked to. Furthermore, I believe Autopipe is still widely used in DOE work...but anyone interested could probably verify that for themselves by contacting Bentley and request DOE references for Autopipe.
Also, seems a bit unfair to post questions about Autopipe or any other piping program on a Caesar II forum. Why not download demos of each program, ask for references and decide for yourself?
Stressed, I don't believe that Isthill posted a link stating it referred to a court case.  I posted the link that referred to old problems with the AutoPipe program.  The intent was to show that it is necessary to personally verify computer programs.  One should be capable of simple hand calculation to verify a program's agreement with simple cases before using such programs on complex problems.
Stressed, if there was a court case resulting from problems with AutoPipe in the 1980s, are you party to a dishonest smear of Isthill?
Why wouldn't this forum be a good place to ask about comparable products with Caesar II?  Many people in this forum have used both Caesar and AutoPipe.  All I see here is Chappy7 asking for first hand experience from those who might be using the programs.  Personally, I need to run a program for variety of projects before I can see the benefits/problems with the interface and algorithms.
The way I see it, these old problems (15 years ago) may have little to do with the AutoPipe program today.  Yet they can be a good lesson for all of us to use in evaluation of new software packages.
CRG
There are a number of piping software products on the market and the choice comes down to what you want it for.  The first commercially available piping product was ADLPIPE and as FLEISHER quite rightly points out there is now a new version ADLPIPE Pro[b].[b]
ADLPIPE is one of the few pipe stress programs that has the full ASME III Class 1 analysis capability and has full NRC accreditation.  In this area there are few that can compete, PSA5 comes close.  Others like CAESAR II avoid this area of analysis and also don't do ASME III Class 2 very effectively either.
It will come down to the projects requirements and personal choice in the end.
pipesRus (Mechanical)
you did not mention BECHTEL ME-101 Pipe Stress Program.
My understand ADLPIPE is now HOT LINK TO STAAD.PRO 2005, Structural software by  www.reiusa.com
Sorry Isthill
You are correct about ADLPIPE and STAAD Pro.  Loads can be exported from ADLPIPE directly into the structural STAAD model.
pipeRus,
        Another software program that has full ASME III Class 1 analysis capability is PSA5. It does not just "come close" as far as I believe is accredited also.
pipesRus (Mechanical) You are correct about ADLPIPE and STAAD Pro.  Loads can be exported from ADLPIPE directly into the structural STAAD model. Thank you.
STADD Pro. Pipe Stress Program 2005 has replase ADLPIPE,
Isthill
'STADD Pro. Pipe Stress Program 2005 has replase ADLPIPE'
This is not the case STAAD Pro is a structural package and ADLPIPE is a pipe stress package, they are two separate packages.  www.reiworld.com gives more details
Mr. Ben Parikh, Director of Corporate Sales & Marketing, Research Engineers International, on June 3, 2005, said the new name for ADLPIPE is a pipe stress package is Stadd Pro pipe stress package.
lsthill,
          Does it really matter what the name is. ADLPIPE has always been known as ADLPIPE.
I see you have shied away from answering "stressed"'s comment "Lsthill, according the information in your link, this was NOT a court case as you originally claimed and your characterization as such appears to be nothing but a dishonest smear." Why may we ask???
Isthill if Ben did say that then he was wrong.  Visit www.reiworld.com for the full explanation.  ADLPIPE will always be name for the solution engine.  What you refer to is the name of the non nuclear product STAAD.pipe, the user interface is called ADLPIPE Pro
As an added note to this discussion,  Bentley Systems has recently acquired the STAAD product line from netGuru, Inc.  Please follow the link http://www.netguru.com/News/PressReleases/PR-082205.asp to read the whole story.  Since Bentley is also the holder of the AutoPIPE product line this will strengthen the interoperability of the two product offerings.
Bentley has a proven track record of acquiring companies with world class technology offerings, incorporating the technology into the Bentley products, providing continued technical support for legacy data created using the previous products and versions, and then retaining the top personnel that helped to make the newly acquired company successful in the first place.
Anyone considering a change in their tools for pipe stress should include a review of how this recent event will effect their long term technology solution.
Is the ADL PIPE also going with Bentley? I know STAAD is a division of netGuru but it didn't say in the press release that all of the products were going. It would make sense if they did. I think the combo of Bentley + STAAD is HUGE. We have been looking for a good CAD + Analysis + Piping Interference/Pipe Load Trasnfer integration other than Frameworks. We have looked at Tekla but it did not handle the pipng and the platform was neither Acad or Microstation. With the forced upgrades from Acad, we are looking towards this solution. if they truly are taking ADL PIPE, I think it will be the first truly integrated structural + Piping + CAD solution all from one company.
The short answer to the question is yes.  The press release was not very clear but the agreement is for the purchase of the REI Division of netGuru which consists of the entire STAAD product line and specifically includes ADLPipe.  You can see all this at the following website:
http://www.reiworld.com/.
