Free sources for material property data
5
What are some good free sources for material property data? In particular I'm looking for info on a broad range of stainless steels.
The ASM volumes are an option but they aren't at ready use. Are there any sites you'd recommend. I want to find some information for a broad range of grades.
RE: Free sources for material property data
SSINA (Specialty Steel Industry of North America) is an excellent source of information on stainless steels.  Check out their publications section:
http://www.ssina.com
As NickE mentioned, Carpenter (http://www.cartech.com) is an excellent source of information.  Other manufacturers of stainless steel with technical information on their websites include the following:
Allegheny Ludlum
http://www.alleghenyludlum.com
AK Steel
http://www.aksteel.com
AvestaPolarit
http://www.avestapolarit.com/
Sandvik
http://www.steel.sandvik.com/
ThyssenKrupp Nirosta
http://www.nirosta.de/nirosta/index.html?lang=en
Another excellent source of SS info is the Nickel Development Institute,
http://www.nidi.org/index.cfm/ci_id/9/la_id/1.htm
with 375 technical papers, etc., as free downloads.
Another great source (& easy to navigate) is the Stainless Steel Property Database at
http://www.hghouston.com/ssdata.html
Stainless Plate Products has less content, but you can find info, shapes & stock quickly for standard grades of SS:
http://www.sppusa.com/reference/stainless_steel/steel.html
Here's a concise page on SS welding electrodes:
http://www.kakani.com/w-stainless_steel_welding_electrod.html
Here's a description of Basic Mill Plate Finishes for Stainless Steel, with surface roughness values Ra
http://www.delstar.com/services/quality/mill.html
Atlas Steel has a straightforward site for SS tech. info:
http://www.atlas-steels.com.au/techinfo/index.html
Edstrom is a specialized site dealing with SS water sytems; deals with chlorination, bacteria, corrosion, lab water:
http://www.edstrom.com/Resources.cfm?doc_id=129
Finally, honorable mention goes to the Australian Stainless Steel Development Association
http://www.assda.asn.au/
This thread should be made into a Comprehensive listing... We could all use a list of the man and varied free list of materials data sources.. i've found out about several through this board...
Hmmmm ..
When I get some free time I'll try and compile a list.....
I'll post here for edits and addendums.
Nick
Thanks for the links guys.
Yeah I'm actually making my own little web page full of good links. I just want the best of course. Sometimes you notice people with a web page full of way too many links. It's hard to know what is useful.
