baghouse fines recycling
can anyone give me some ideas on how to recycle about 100 metric tonnes of baghouse fines waste from an asphalt coating plant? is it possible to turn this material into lightweight aggregate and how?
RE: baghouse fines recycling
Good luck
Thanks Smile1
The compounds are likely to change in the baghouse fines as the raw materials vary from limestone to metamorphosed sandstones to a combination of both. The quality control on the fines would probably be too complicated a process. Any other ideas on recycling as opposed to adding back into the asphalt? The plant burns recycled oil, so the fines are pretty nasty.
