cmos - ttl problem
cmos - ttl problem
I have to connect this temperature sensor to the PCs parallel port. So I connect the sensor to adc0804, which I think is CMOS based. Next I need to connect the 8 bits to the PCs parallel port. So I use 2 quad bus buffers, 74125. The buffer is ttl-based. The pc's parallel port considers 5V as on and 0V as off. So theres nothing wrong with the buffer.
But how can i connect the ADC0804 with the rest of the ttl-based circuit.
RE: cmos - ttl problem
Suggest you find a book on the IBM PC hardware.
Otherwise, what would be the point of using bus drivers to drive loads you can't drive, if you can't even drive the bus driver?
TTFN
What about using a fast USB? Visit
http://www.picotech.com/data.html#temp
