How do I determine db9/db25 pin status with viisual c++
How do I determine db9/db25 pin status with visual c++ ?
I need to read a 1 or 0 from the db9/25 according to certain conditions.How do I do this? I need a class name from the MFC.
C1600@univtech.co.za
Please this is urgent.
Thanks.
RE: How do I determine db9/db25 pin status with viisual c++
#include "conio.h"
#define DATA 0x378
#define STATUS 0x379
//for writing
_outp(DATA,4); //where 4 is to be written to data port
//for input
_inp(STATUS);
/*the addresses given are the common ones for the DB25 parallel port. Data or output port is an 8 bit port white status port takes it as an 8 bit data but allows only 4 or 5 input pins. Refer-
http://www.indiacam.net/pinout/#3 for pinouts.
Aditya Singh
