Working Examples
Working Examples
Hi all,
I've recently started to learn V5, having been a V4 user for many years. I find the easiest way to learn is by doing working examples. I've managed to locate a couple of these on the net, but would like to find some more. The PracticalCatia ones were good, but a little basic. All I was looking for was a list of steps required to complete various modelling/assembly/detailing tasks.
Also, does anyone have any tips for the basic techniques for using the commands/icons??.. e.g. manipluation of icons etc, command structure.
For example, how do you do things like multiple translations?.. I seem to be re-issuing the command for each individual element.
Sorry for the epic.....just can be a bit fustrating at first.
RE: Working Examples
If so, notice that every product has mini-tutorials with accompanying sample work models. You can spend many hours working through what is provided by CATIA, then buy Cozzens V5 Workbooks I and II.
www.schroff.com
Don't forget that the last documentation disk is a folder of PDF manuals to study and print out.
Is that what you are trying to do?
If so, I hope this answers your question.
I'm in the opposite situation, I learned V5 and and now teaching myself V4 for my current job.
Michael
That's a switch - learning V4 after using V5! Care to share your experiences? I imagine you find V4 very difficult? Do you use the V4 sketcher?
thanks, ...Jack
A small tip for "re-issuing the command " again and again
Use the command "Repeat"(Ctrl + y) . This will repeat the last executed command.
for example after creating a fillet u can select " repeat command to get the fillet icon". Take care not to use it after undo as it will redo what ever was undone.
Cheers
Ganesh.N
ganesh.n@engg.tjc.co.in
Check FAQ.
Fernando
