S-N Curves for Bolted Joints - need good reference
I am looking for a reference with S-N curves for bolted joints.  The joint we're considering would be like a diving board with a bolted support, so the bolts could see a prying action.  Does anyone know of a good reference for those curves?
RE: S-N Curves for Bolted Joints - need good reference
I would contact the bolt manufacturer.
A good rule of thumb is .57 x the
maximum tensile strength for dynamic
applications.  The manufacturer should
have run many tests on their bolts and
have this information available.
BS7608 has what you require
