Multiple Curves as trajectory
Ok guys, this is more of a "why in the world" post. Been stumbling around trying to create a swept protrusion using multiple datum curves. Problem is, I used some "thru points" curves and pro e tells me that is not a valid trajectory. Even looked it up in the good old trusty help file, says right there...pro engineer will not sweep along a thru points curve (although i've done it). So, I tried using swept blend option...and it works....everytime.
Anyone shed any light on this??
RE: Multiple Curves as trajectory
Steve
http://www.3dlogix.com
I don’t use a lot these options so it didn’t really bother me, because there is always a plan “B”
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
1. Creation of "Curve thru points":
- Select start point in consistent direction.
- e.g. if you want to sweep from left to right, then the very left need to be the starting point. Same goes for the tan curve.
2. Tangency of starting point for traj and tan traj must be the same.
Hope it helps.
Kenney
