Revision Table - how to create a default version
Inventor 6 Revision Table is very usefull.  Except that I want to use my own format to match the companies existing drawing blanks.
Is there a way to save the table format once you have edited it and then call up this version onto a drawing sheet?
Even better is it possible to combine this with a drawing border or title block so it appears automatically?
Nick
RE: Revision Table - how to create a default version
If you change it, it changes in all the sheets.
If u change it in your template it will change in all of your new drawing.
Good luck
Zachi Gat
Thanks for your reply.
How do I save it in a template?  I have tried this but everytime I call up the template the revision table is missing.
Nick
Hi Nick...
I haven't tried this with the revision table (and don't have Inventor on my home machine - so I can't try it), but to confirm that you are saving the template correctly:
Under Tools > Application Options > File Tab, your template directory location is specified. Save your modified drawing template to the folder that's pointed to there (by default, C:\ProgramStupidMicrosoftNamingSystemFiles\Autodesk\Inventor6\Templates...)
Then start a new drawing selecting your modified template.
If you already knew that then.... I haven't been very helpful have I!?
Col.
I beg to differ.  I just created a new IDW file, inserted a Revisions Table and edited it so it was how I wanted it.  Deleted it and then put a new Revision Table in and the format held.  I then saved this into my template directory with a new template name to test.  I started a new IDW and used that as my template and when I inserted a Revision Table it was back to the original format.  Did not hold the table format I created.
Any other suggestions?  Please?  :O)
Scott
    ~ Phlyx ~
submit a bug report?
