surface charts
surface charts
I'm using Excell to get 2D charts.
Now I need to plot some 3D surface charts and found out that Excell is not the right software for that (its surface charts don't look very nice).
Can you suggest me other software for that or, maybe, any Excell add-in?
thanx
thanx
RE: surface charts
the resultsing charts will be much better than excell ones
RE: surface charts
Axum runs as an addon to EXCEL. PSI Plot is a independent program. Both give great surface plots.
RE: surface charts
RE: surface charts
For 3-D curve-fitting, I wound up using using TableCurve. It is easy to use and spectacularly fast. It may have been supereceded (sp?) by now.
