I was hoping someone might have kno
I was hoping someone might have knowledge regarding weir coefficient for a 8-inch thick concrete V-notch weir with a 10 degree or 15 degree opening or rating curve for a structure such as this to a depth of 4ft. Any help would be greatly appreciated.
Rob K
Rob K
RE: I was hoping someone might have kno
Q=0.86H + (3.65w + 5.82z)H^3/2
Where H = Upstream Head & H</=6.0'
z = slope of slot sides, z horizontal:1 vertical
w = slot invert width at base
Limits for z are 0.60>z>0.00
Limits for w are 2.0>w>0.33 ft.
You could set H at 4.0,w at 0.33 and z at 0.27 to get an overall Q then reset and subtract out the value you obtain with z at 0.0.
This equation is used pretty extensively in SW Missouri.
Good luck.
