Weldable Bolts and Nuts
Where can information be found regarding what types of bolts and nuts are weldable. And from that, can these welds be designed using the same parameters as those for "typical" steel members?
We want to use a threaded rod or bolt as a tension/compression member between two pieces of steel approximately 24" from each other. The bolt would extend through holes in each piece of steel.
Due to accessibility, we prefer to weld a nut to only one side of each piece of structural steel. With the bolt in tension, the nut would bear directly against the steel. With the bolt in compression, the nut would transfer forces through a weld (all-around) to the structural member.
RE: Weldable Bolts and Nuts
You can also weld A-325 type/grade C nuts for higher strength, and also leave them as-welded.
Be advised that fillet welds, such as you plan on using, do not in general have real good fatigue-crack resistance, so if your loads change rapidly/frequently from tension to compression make sure you take that into account.
Textron Fastening Systems - http://www.textronfasteningsystems.com
Emhart Teknologies - http://www.emhart.com
CoryPad, great references. Unfortunately, the particular loads in this situation are too great for any of their fasteners. I looked up projection nuts at Buckeye Fasteners / Ohio Nut & Bolt Company, but even they fall short of the particular load we are trying to transfer - about 4500 lbs via a 3/4" threaded rod through a nut and into a plate.
If you are going to weld nuts to both members, how are you going to thread the bolt in place? Or are they to be welded after the nuts are in place?
If you must pursue this, perhaps use a sleeve over the bolt between the members to increase the compressive capacity.
