How to Run Both 2001Plus & 2003 on the Same System
I have one customer that requires 2001Plus and one that requires 2003. It seems like, on the other systems I have upgraded to 2003, the 2001Plus was overwritten. Is it possible to run both? If so, is there something special I have to do when loading it?
Thank you
Thank you
RE: How to Run Both 2001Plus & 2003 on the Same System
If you use common parts, templates, and formats you will need copies of these for each version, too.
Personally, I would be unsure of a customer who was not willing to pay the price for support and the upgrade to 2003.
Crashj 'how long will this be going on?' Johnson
As for the customer on 2001Plus...They have a really bad company that handles their SmarTeam software. The last they told me was that they were told that they couldn't upgrade to SWX2003 because their version of ST doesn't support SWX2003 and the new version of ST will not be out until somtime in April. I know that the new version of ST is available right now so I am not sure what they are talking about.
Thanks again
It sounds like your customer needs to start shopping for a new VAR.
