Attention! Error in API 617 ??
Standard API 617 it. 2.9.5.5. wrote: "During the shop test of the machine - assembled with the balanced rotor, operating at its maximum continuous speed range - the peak -to-peak amplitude of unfiltered vibration in any plane , measured on the shaft adjacent and relative to each radial bearing, shall not exceed the value in Equation 5 or 25 micrometers, whichever is less:"( ? peak-to-peak? 25 mk peak-to-peak - this is very small and Equation 5 not working) Is this right or not and why?
Any information would be greatly appreciated. Regards, Jurry.
RE: Attention! Error in API 617 ??
