Allowable Fillet Weld Stress Limits
Hi Members,
Can anyone help? I have a situation where carbon steel is welded to stainless steel using fillet welds. There is a differential expansion between the two materials which results in shear stresses within the attachment weld. The problem is what is the allowable stress limits which should be used to check on the weld sizes? Although the Codes give values for allowable shear for fillet welds these are primarily for a situation where the load is of a Primary nature and not of a secondary nature as in my case. Can we use the allowable shear stress for the weld (or weakest base material) multiplied by 3 (ASME allows 3Sm for secondary stresses)? Please give your thoughts
Thanks in advance.
Thanks in advance.
RE: Allowable Fillet Weld Stress Limits
prex
http://www.xcalcs.com
Online tools for structural design
