Obsolete Modem Data Sheet
I am looking for a data sheet on an obsolete modem IC, AM7911PC made I think by AMD.  Someone must have a copy lying in their archives!  Thank you for any replies. (Same query posted on the electrical forum by accident!
RE: Obsolete Modem Data Sheet
I looked at several on-line sources that I use without success, but finally found the AM7911PCB (slightly different package option).
You can get a copy on www.freetradezone.com - if you register as a member.
If you can't get a copy from there then let me know your e-mail address and I can send you a pdf copy (40 pages!)
Thanks for the reply BrianG I will continue my search in that area
Modemman
FAO BrianG, Thank you for your advice freetradezone gave me what I needed
Modemmnan
