Command to Open "Save As..." Window
I'm trying to write a macro that on a button click, opens another file then opens the "Save As" window so that the user can enter a new file name and location of their choosing.  I have no problem opening the file, but the ActiveWorkbook.Save As command wants to actually perform the save as function immediately.  I just want the macro to end by leaving the Save As window open.
Thoughts?
-Mike
RE: Command to Open "Save As..." Window
Mike,
There are a couple of ways to do this.  Here are two  procedures that demonstrate the general ideas:
Sub ActiveWorkbookSaveAs()
Dim FName As String
  FName = Application.GetSaveAsFilename(InitialFilename:="", FileFilter:="Microsoft Excel Workbook (*.xls),*.xls")
  If FName <> "False" Then
    ActiveWorkbook.SaveAs FName
  End If
End Sub
OR
Dim Result As Boolean
  Result = Application.Dialogs(xlDialogSaveAs).Show
End Sub
Notes:  Set InitialFilename to a nonempty string to display a suggested filename.  FileFilter can include multiple file types.  Keep in mind that GetFilenameSaveAs only returns a file path and name as a string.  You can do whatever you want with this; in this case, you are supplying it to the SaveAs method.
Look at the VBA Help for the GetFilenameSaveAs method and the Dialogs collection (built-in Excel dialogs) for more detail as well as additional parameters.
Mike
Mike,
Excellent!  This is just what I was looking for.  Thanks.
-Mike
