Electrostatic Oil Cleaners for Hydraulic Systems
I am looking for information on electrostatic oil cleaners, for use on a hydraulic oil system. We are having problems with the build up of varnish in the system. The hydraulic system is used on a steam turbin and operates at 1200 PSI.
Can anyone point me to a good sourse of technical information on these types of oil cleaners? I have found some information using Google, but not much.
RE: Electrostatic Oil Cleaners for Hydraulic Systems
This method is old but it works quite well.
Look under Dr.Cottrell of the Research Cottrell folks.
Dr. C developed the lamella buster that destroys the chemical formation of the varnish.
Write bach if you need additional help.
