PDF Files
PDF Files
PDF Files
Does anyone out there have any experience with creating Adobe Acrobat PDF files from AutoCad.  We currently have a PDF writer we got with our scanner software but it only creates drawing sizes no larger than "B" size (11" x 17") so that "D" size drawings are scaled down to "B" size.  We would like to create files that are "D" size (22" x 34").  Is this possible with Acrobat?
Steve Smith
Product Engineer
Staco Energy Products Co.
www.stacoenergy.com
RE: PDF Files
Dont u have to use Adobe Distiller to do this? just a thought.
RE: PDF Files
Only with the full version or one of the adobe products that installs a PDF printer (which will show up in your start>settings>printers area)use that to print
RE: PDF Files
Hi Steve,
If you go to the web site www.contlp.com there is a free download called 5D PDF creator. this has all the variables you require. I ahve been using this with both ACAD14 and 2000.
RE: PDF Files
Thanks Robin,
But are you sure thats the right address, it seems to be a dead site.
Steve Smith
Product Engineer
www.stacoenergy.com
RE: PDF Files
Hi Steve, Don't want to butt in here on Robin, but I too use the Jaws PDF creator and it works great,with TurboCAD can't beat the price, or at least you didn't used to be able to. At first glance it almost appears as if they're charging for it now, have a look at http://www.pdfsoftware.com/index.html and see what you think...Mike
RE: PDF Files
Robin & Mike,
My thanks to both of you.
Steve Smith
Product Engineer
www.stacoenergy.com
RE: PDF Files
The free version is an old version of PDF Creator v1.52. The homepage for Jaws PDF Creator v2.0 is http://www.jawssystems.com.
Amber
RE: PDF Files
dear friends!
i have the just same type of problem
my problem is can we convert pdf files into microsoft excel files?because if in pdf files ,if tables are there.for converting those into rows and columns like table.any idea greately appreciable.
