CMP point repair
CMP point repair
I am investigating methods to point repair a 60" CMP sanitary interceptor. The crown of the pipe has corroded and is failing in some areas. The sections are limited in length (usually 5-6' long).
Is anyone familiar with methods of reparing the pipe short of direct replacement?
RE: CMP point repair
You might also consider PE pipelining if you can find it in this large a size.
Although expensive, replacement may be the best long term solution because this pipe is well on the way to total failure and possible collapse. What would the cost of that be?
