3D datum curve into segments
I created a 3D datum curve and am trying to section them into different segments. The first step I need to finish is creating datum points along the 3D curve in order to use them as references in the split datum function. My problem is with the datum point creation. There is a feature called "Actual Len" in the Create Datum Point> On Curve menu that allows me to specify a curve length. It is using the wrong end of my curve as the starting point reference. Is there a way for me to change this?
RE: 3D datum curve into segments
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
first you select pointon curve,than it gives actual lenght wherever the point may be, it gives whole lenth of
curve and which point u want make it subtract and gives the data, you will get that point
i hope this will help you
Nagaraj
