Adding a Diametrical Datum
I'm looking to add a diametrical datum call-out on a shaft. I want it to be the square call-out with the filled triangle in line with diameter dimension per the ASME Y14.5M-1994 standard. The dimension is on the profile view of the shaft. I cannot for the life of me find a clean way to do this. I can float the symbol on one of the outside arrowheads, but it looks bad. I tried to delete the arrowhead, but both disappeared.
Any help is appreciated.
-Mike
-Mike
RE: Adding a Diametrical Datum
go to tools/options/docment pro., dimention standard selected ANSI, and select display datum per 1982, that will work.
Fechoo
lz244@hotmail.com
