ProE slow on a network
Are there any good practices or settings such as location of config.pro or working directory location when handling large assemblies over a network.  All actions seem to be slowed down to a crawl, saves, modification of dimensions can take 30+ sec each.  Life was soo much easier when all work was local but we all have to share.
RE: ProE slow on a network
Temp files on the local drive.
If using Pro/I, workspace on local drive.
Working directory on local drive.
Pro/E code on local drive.
Filing to the network drive only when you have finished your work or at the end of the day. Local drives are not usually backed up.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
