Cross Section text
Cross Section text
Hi All
Is there a way to change the system defaults for the text thickness shown on cross section arrows i.e A-A. I have found one spot but it affects all text and dimenions.
Then when you place your section view the text header is placed like this (section A-A), two sizes of text with different thickness or fonts.
Thanks for any help
Tofflemire
Thanks for any help
Tofflemire
RE: Cross Section text
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
Yes you are correct, I want to be able to set this so this in Config.pro or Drawing setup file (.dtl) so these little over sites get done automaticlly.
Thanks for you input
Tofflemire
im4cad
